1 - 7 of 7 Posts
its been going on since ive had the thing. what it is, is a skretching/ grinding noise coming from the clutch...i think. it happens when i start from a stop. it dosent happen if i let the clutch out slow. anybody know what it might be and how to fix it?
It's normal on the RFS motor, you can remove the outter steel in the clutch basket and sand it lightly, that should cure it for a while, it's just clutch chatter, helps to change oil often, mines also does it. hope that helps
really thats normal? it just sounds like something is wrong...
its normal, we tore my bike apart 4 times looking for it but then we started up 3 more and they did the same thing
1 - 7 of 7 Posts
