Just wanted to share the some details I found on the 450/505sx con rods.
Pro-X 505SX 291 grams
Carrillo rod 268 grams
Stock rod???
Anyone have weight numbers on the stocker? I haven't pulled my stock rod out yet for measurement.
23grams between pro x and carrillo.I think that's a nice amount of rotating weight that can be eliminated by going with Carrillo and should help with the longevity of the lower rod bearing.
Remember a 450 and a 505 rod are different. I have a stock 505 rod I can weigh to add to the list, but it won't be this week. Would need to get some scales from a friend of mine.
i have a 505 rod at home, but I'm a thousand plus miles away.......... from memory there was bugger all difference stock vs pro x. to get the true picture you need to wiegh the rods end for end. change in weight at the big end vs small end.
Whilst it all helps the piston weight has a far bigger effect as it's all hanging off the end so to speak.
So two sets of scales with each end of the rod right in the very middle of each load cell. Ill see if I can manage that. Failing that you'll need 1 scale and a surface the same height. May even be able to use a small bit of bluetack so the rod sits on the narrow end.
Cool,the reason why I'm looking into this is because after the rebuild my motor vibrates more than it used to..My builder told me they balanced the crank but I'm not so sure.A perfectly balanced crank/rod/piston should not have as much vibration as I do now.
The dot needs to line up with the pin that goes through the cover. I didn't even make a pin i just used small metal rod that fit snugly through the hole to hold the gear in place.
well the lighter rod will have altered the balance % for a start and not necessarily in a good way it would seem ?
Secondly "balancing" all depends on the balance factor used or % value as it sometime referred to, this is critical, needs to be around 62 - 63% for a big single, this is way different to what allot of car / multi cylinder guys would do, (50%)………….
Agree Craig,according to another builder..anytime you add or subtract more than 20grams from the stock config,the entire assembly should be rebalanced..I'm wondering how much weight was taken off or added by going with the Carillo rod,from there I can figure out what's what..
Hopefully I should have my carrillo (450) rod next week, just really worried how I can get the crank balanced.. cause I dont trust any workshop in my area..
Been looking around I found this great video:
[video=youtube;Jn50F_yKW0s]http://www.youtube.com/watch?v=Jn50F_yKW0s[/video]
Ok, it says harley, but the guy explains a lot of stuff
My goal is to understand how it balanced, measure the conrod at each end (I have the means to do it), calculate the weight, make it, and give it to the guy to balance the crank.
Only that way I can be sure
Related Threads
KTM ATV HQ Forums
108.4K posts
25.5K members
Since 2008
A forum community dedicated to KTM ATV owners and enthusiasts. Come join the discussion about performance, modifications, classifieds, troubleshooting, maintenance, and more!
