Finally got around to examining the head a little closer. There was 1 intake valve leaking and 1 exhaust leaking. I did not have to vacuum test the head to notice this. When looking at the exhaust seat, it was evident that it was not sealing. Usually when you have a good seal the 45 deg. angle on the seat is shiny. This one was shiny only about 3/4" around. One the intake side, same description with carbon build up on the tulip of the valve.
This could be a result of mass production or sometimes on a new head/new valve seats, it's not uncommon to have things settle in with heat. I am not trying to bash Ktm, I have seen this on other engines as well. I am sure with a couple more tanks of gas threw it it would of settled in along with rapid valve wear.
A pic. of the intake valve, most obvious way to tell if the intake valves were tight or leaking
