1 - 11 of 11 Posts
forgot to ask....r they accurate......
i tested mine with a temp gun and it was with in a few degrees which is close enough, i compared the hose along side the gauge to what the gauge was saying so that might have been the difference, the outside of the hose to the actual water temp
Discussion Starter #6
thanks ronn.......do u have any idea how much they go for....
not currently, if you do a search on ebay a bunch will usaully pop up, i think the low side is probally 40 bucks up to 100 or so, depending on what you want and how plain you want it to be, just have to check it out.
370165822559
370165819429
check these item numbers out, a couple examples
Discussion Starter #8
370165822559
370165819429
tx ronn
1 - 11 of 11 Posts
