Team
This is the low down from Ohlins:
The standard fitted spring rates are
Front mains 21-30 newtons or 120-171 lbs (270mm long)
Front secondaries 30 newtons or 171 lbs (60mm long)
Rear ( no secondary ) 62 newtons or 353 lbs (free length is 250mm)
Ohlins Spring recommendations, GNCC, for use with there revalving recommendations and Ohlins GNCC race kit KT772 which shortens the shock length (but maintains the shaft travel) lowering the quad.
Front
Main Support
06380-03 04060-30 Light rider 75 kg / 165 lbs
06380-04 04060-40 Medium 85 kg / 187 lbs
06380-05 04060-40 Heavy rider 95 kg / 209 lbs
Spring Code length Spring Rate
06380-03Y 260mm 18-27 N/mm
06380-04Y 260mm 21-30 N/mm
06380-05Y 260mm 24-33 N/mm
04060-25Y 60mm 25 N/mm
04060-30Y 60mm 30 N/mm
04060-31B 60mm 30 N/mm
04060-35Y 60mm 35 N/mm
04060-40Y 60mm 40 N/mm
04060-41B 60mm 40 N/mm
Rear
Main Support
06330-18 05060-10 Light rider
06330-20 05060-10 Medium
06330-24 05060-15 Heavy rider
06330-14Y 175 60 N/mm
06330-16Y 180 64 N/mm
06330-18Y 180 68 N/mm
06330-20Y 185 72 N/mm
06330-22Y 185 76 N/mm
06330-23Y 185 78 N/mm
05060-10B 55 100 N/mm
05060-15B 55 150 N/mm
05060-20B 55 200 N/mm
Multiply N/mm by 5.7 to get Lbs/in
FRONT, the springing is actually this&&&&&&&.stock main springs are as per ''medium'', but the smaller secondary springs are the light setting at 30 newtons. The ''medium'' secondaries are rated at 40 newtons. ( There is also a 35 newton option listed )
Y = Yellow B = Black
Front
Main Support
Rear
Main Support
