So I am in need of the complete tie rod and ends, not because I wrecked but because 2 of the 4 end's boots are busted.
I am looking at these ( disregard the quad selection), So I called them and they think they fit our quad, but will call me back to confirm. Doe anyone know if these work, or if their is a set for around $150.
New OEM on Rocky is about $110 per side, I have Houser Slicast A arms , stock travel.
Thanks
ASR PRO X-SERIES RACING TIE RODS are manufactured out of
Precision Formed, Seamless, Heat Treated .120 Wall 5/8 inch
Aircraft Grade Tubing with Stainless Steel Threaded Ends. The
stock style tie rods and rod ends. With most OEM tie rod ends
being about 45.00 each (x4) you can see why these are the best
Rod Set! Available in Stock, +1, +2 and +3 lengths. Lifetime
structural warranty too!
KFX700 A-Arms, Steering Stems, Tie Rods, Brake Lines, Bearings & More
I had a problem with my boots splitting. I replaced all my ball joints with OEM. I then drilled and tapped a hole to put a grease zirk in the back of the joint, I haven't had a boot break since.
  • Like
Reactions: rc51ner
