1 - 7 of 7 Posts
Just wanted 2 find out if any of you guys are using the rear spacers with the stock rims. I just changed them out and it looks pretty wide. I'm sure it will handle better, but I dont want 2 be worriying about going between trees.
Im running them wide with dual beadlock hipers. No problems yet
I was told with the hipers that the rims set in further so you can use the spacer. Not sure! I messured the width and it was over 47" What about yours..
Mines right around 47-48". Should be alright if everyone cuts the trails as there supposed to. MIN 50". I've done 2 races this year so far and not had a prob yet
Thanks for the info. Ill stick with them on then.
1 - 7 of 7 Posts
