Has anyone done anything to lower the rear ride height yet?
I changed my rear spring rate to a 5.6 lowered to 7 1/4Has anyone done anything to lower the rear ride height yet?
So how is the suspension (in general) setup from the factory? Are you for the most part satisfied with how it feels or are you guys finding that a revalve/respring is needed?
thats cool, I've heard a lot of good about the Olhins. I suppose it was to be expected that the Stock setup would be kind of stiff because they need to make it fit so many different people.mostly respring pretty stiff from factory, mainly need to get ride height lowered then factory valving might be to your liking I revalved mine I like riding on clouds LOL can't do to much big air now but in xc there isn't much anyway. takes all the rough stuff like a dream.
Palo Verde in Arizona did mine much cheaper . Its day and night differance. I had been ridin Elka, but after redoing Ohlins much more happy with them than Elka. All I was saying getting it lowered might make it better for some people. They are way harsh stock but still better than everyone elses stock set upfront and rear shocks have to much low speed compression / rebound, this causes a harsh ride in the front and causes skipping in the rear. A revalve is defintely needed, whats annoying is that teh factory could get this right from the get go, it's simply a case of altering the shim stacks. Whats the point of 20 clicks off adjustment is the lightest settings are still to harsh...........
Rear end rides arse high, creates an uneasy sensation over jumps and drop off's, rear spring is a bit stiff and really needs to be a dual rate to get the ride height down and make it more supple in it's action. GT thunder has a full front rear package for 0 that will apparently cure all issues.
see the ohlins post, there is alot more going on than a simple revalve.............
