Actually, I m sure I won't be doing any mods, most probably going to get harder springs(right now I m 245lbs. Do ) do you know where I can find some by the way? I really don't know anything about atv's (nor bikes) I m learning...
About the jetting, I would like to know what jets are just for sea surface riding (I assure you I won't going more than 100ft). I m getting the kit and the jet I need(I don't want to get lost lol, I m already on unstable ground) knowing that it can gets over here in temps from 25°C to 35°C (75°F to 95°F) and humidity is always around 80% more or less.
Also, I d like to know more about the deal
To The Springs, 245lbs .... your fine. Your front shocks turn them all the way clockwise (top nob) after they gone all the way, turn them counter-clockwise 10 clicks. On the bottom of the shock there is a small screw located about 1/2 inch above the bolt that attaches to the A-arm, turn it all the way clockwise then counter-clockwise 8 clicks. Do same to both sides.
page 29 of owners manual
Rear, top knob turn all the way clockwise then counter-clockwise 5 clicks, bottom of shock there is return dampening. Refer to page 32 in manual, turn it all the way right then turn it left 4 clicks.
Setting should work pretty good for ya. If you want it perfect to match you then look up rocket Ron on this forum and you can send him your shocks for a custom fit.
You plan to stay at low sea level .....
Get Jd jetting
Use Blue needle 3 clip
185 main Jet
45 Pilot
Fuel mix screw 1 1/2 turns out (buy a fuel mix screw, it will sit below your carb for easy access, if you install your self be careful when removing the factory fuel mix screw, there is a spring and small washer that can fall out and be lost easy)
Take these steps and you will be running just fine.
