1 - 5 of 5 Posts
I think mine is dead and I need to borrow one to confirm it...
I can't stomach buying one and that not be it.
Have you checked your TPS.
Bronson sorry to hear about the challenges you are encountering...mine is in the back of the Toyhauler, but could get the wife to let you in if that is feasible...have a 41mm Carb off a KTM 520 SX with TPS sitting on the workbench in my garage also...JD Jetting Kit with the Blue Needle left over...should be able to get to the CDI mine easy enough if you back the Z400 out of the way or maybe you wouldn't have to move it at all...let me know if we can help...got my 570 Kit on the way I am going to go with a custom grind 8/07 cam instead of 8/06 or 8/33 and 43mm Oval Bore Carb...
Take my Quad with you for spares if you need it...you can dyno it too for me!!!
Something that happen to me one time ..... got my throttle cable under my gas tank and it had just a slight pull on it and it wouldn't start. That switch in the throttle is a pain.
-Voodoo
1 - 5 of 5 Posts
