1 - 14 of 14 Posts
Well after my ktm/cr500 build turned out to be a big mistake I sold the engine and started a ktm/trx250r build, after fitting the engine swingarm mount and bottom mounts I had my local mod shop fab the front engine mounts and a fatty pipe made to fit the chassis, after putting 10 hours on it and not being able to take the smile off my face when riding it I decided its time for some more horsepower :) I contacted arlan at led preformance about building a 431 puma engine and custom exhaust and intake and he was excited to take on the build :) I found a good engine that has only been opened up once and a low hour 525xc rolling chassis to start this build fresh, arlan should be starting to work on the engine this month and then I have to ship him the chassis.Plans for build,Engine:-431cc CPI puma big bore kit,-led custom porting,-welded and balanced crank with ktm rod,-sling shot clutch,-cyroed and back cut tranny,-Ricky stator ignition to run lights/fan,-led exhaust and intake,-40mm billit smart carb,Chassis:plus 4 swing arm,-shocks ?,-all black plastics,-custom rad decals,-carbon fiber steering stem/bars/tie rods,-sx a-arms/seat/fuel tank,-presision steering damper/antivibe bar clamp,Here's some pics of the swingarm mount and front mount, I'm gonna let arlan do the bottom mounts, more pics to come
What kind of riding do you do? Where? Just around GP? Should be a beast
I just ride trails/dunes/dirt roads and go to Brule on the long weekends, I'm really gonna try to keep this one strictly dune quad, hopefully get some trips to Oregon dunes
let me know when you will be taking it to brule. I go there quite often and would like to see it go.
whats the plan for kickstarter fitment with frame?... very interesting project! I wish Arlan will keep the templates for the pipes and engine mount...!
Discussion Starter #10
Just using a stock kicker, it fits perfect under the frame rail but theirs not much forward movement so might have to use a decompression button on the cylinder, I'm sure he will keep the templates, I think a lot of ppl will be interested in doing this conversion if it turns out good
Awaiting the ride report!
1 - 14 of 14 Posts
