1 - 20 of 23 Posts
ive read it somewere on this forum but i cant find it again, its the write up on relocating the intrument cluster from the front bars to the front hood, i cant see it being to hard just want to have a look how its done and my next question bout doing it is all the holes for both the ignition and the indication lights all have a square recess to stop the light spinning. how did you guys combat that when drilling holes to relocate everything.
I bought a panel for the clamps from Rox Speed Fx. the only problem is that you can't run a bar pad. check out www.roxspeedfx.com
I relocated mine to the front hood, and the key to the side. real easy, just drill the holes. The ring clips on the instrument cluster lights hold them pretty tight, mine dont spin at all
Hey Patrick, can you throw up a pic of the panel installed on your quad? I'm thinking about buying one and wanted to see what they looked mounted up. Thanks
Heres mine with Flexx Bars, looks and works good. wasnt to crazy about the key position, but it grows on you!
Looks good, question for ya. what is your bend on the flexx bars. is the 14/31 or 15/31
Thanks! Can you get a pic of the front view by any chance? Looks pretty good from the pics!
Heres one,
I will try to get another later today, a couple of more angles.
Check these out if you get a chance. We are a new site sponsor.
These will be available in bare aluminum, stealth black ( to order ), and soon these will be available in 100% Carbon Fiber.
**Also, I will post new pics tonite or tommorow morning as I did change the design a little bit for a better look**
I like the way those look! They will will look really good in carbon fiber! I just wonder if you'll be able to the lights if you're running Flexx Bars? Have a pic with one mounted yet?
I don't have one mounted yet. My goal was to keep it as little as possible to reduce the bulkyness that the other ones carry with them.
Sleek is good, and they might be able to be flipped to run above the gas tank. I'll check fitment tonite or tommorow and snap pics for ya.
Sorry about the delay, but I wanted to make changes so had new ones made.
Thanks, Jay
Cool, Like I said, I like the look. And I think they will look really good mounted!
1 - 20 of 23 Posts
