I hope this will help you.It's not that difficult to adjust the TPS.I know a jet kit has nothing to do with the spark, I have taken the spark plug an checked it they are no spark... How do I adjust the tps??? I have never messed with this type of setup, an my last bike was a ltr so I've not messed with a carb since I had a 450r back in 04... Thanks for the help...
It could be that the TPS is out of range because you have turned the Idle srew to much or the TPS is loosen. (There is a green mark on the TPS on the carb.)So what do you do, hold the black idle knob in place an adjust the actual screw????
There is no screw like the idle or air-fuel mixture srew.I still don't understand which screw Is the tps adjustment.
