Hey guys, this is just a post out here to help you guys get hood jetting in your bike as well as a hood riding experience
I run my bike at sea level so keep that in mind
I run a 11.1 vertex high compression piston, FMF powerbomb header, and fmf mid pipe as well that runs into an Hmf slip on at the end.
I’m running a stock bore on my carb
175 main jet
48 pilot jet
85 starting jet
I’m pretty sure I have the HRC Needle which has 7 clip settings total, I’m running it on the 4th clip from the top.
Im also running the accelerator pump O ring mod.
starts really really quickly and runs amazing
I think I’m around 2.8 to 3 turns out on the air/fuel mixture screw.
It pops only when you really hit it hard and let off, it’s not often tho.
If you guys have questions just reply.
175 main jet
48 pilot jet
85 starting jet
