We are going to put a 15 tooth on my wifes to help keep from blowing the tires off in first gear.Has anyone gone up a tooth for more top speed? I feel like i run out of gear up top? If so, did it change small woods trails at all for you or are you still pretty good in the powerband.
Renthal makes a orange 36 tooth rear sprocketive gone up to 15 t front and down to 37 rear and it still wants more ...
So going up a tooth on the front sprocket and down a tooth on the rear will increase top speed and decrease acceleration? Do i have that rigth? i was thinking of gettin different sprockets to up the speed
yup!So going up a tooth on the front sprocket and down a tooth on the rear will increase top speed and decrease acceleration? Do i have that rigth? i was thinking of gettin different sprockets to up the speed
Isn't it 15T stock? hmmyup!
i'm up to a 15 tooth front, cant fit anything bigger then that, even a 15 is snug
i've been tossing around dropping a tooth in the rear but i might wait till this fall
14 is stock
Be VERY careful the damn sprocket bolt is SOOOOOOOOOOOOO tight, and the bolt is soft as butter. Many break off, I broke mine last night!![]()
Oh, I was SO sure that it was 15. I bought a new sprocket, chain etc. didn't think of what size the org was. So I'll se if theres any differens then.14 is stock
The stock rear is 38, right? I am waiting on new 39, what does that do for me with stock front??? do i loose somthing or gain somthing??
Thanks
I run 14(stock) front and 39 rear on my 450xc. I race WORCS and this gearing helps in all types of terrain. Also helps when exiting a corner. On the DYNO. It still hit 70 mph. Just barely though. I like this combo. But that's me. Good luck.The stock rear is 38, right? I am waiting on new 39, what does that do for me with stock front??? do i loose somthing or gain somthing??
Thanks
Could someone help me by sending me the link from Renthal's website for a 36 tooth rear sprocket. I am going to be running 15 up front and 36 in the back for flat track next year, but I looked everywhere amd could never manage to find a 36 tooth sprocket for my 525.Renthal makes a orange 36 tooth rear sprocket
