Hey Trew was wondering if the go for it graphics number backgrounds on your xc would be a good fit on the sx? I am wanting to get a set. Thanks.Modlist: I'm sure I'm missing stuff
Chassis | Suspension | Controls:
Frame: 4130 Chromoly Stock
A Arms: Walsh RaceCraft +2 LT Flow : KTM Encapsulated Balljoints
Swingarm: Stock 4130 Chromoly
Steering Stem: +1 SX Billet Aluminum w/ Ajd. Clamp
Stbilizer: Elka Factory System 5
Axle: RPM Dominator II +4 Adj.
Carrier: KTM
Locknut: RPM Billet w/ Pinch
Hubs F|R: Rath Racing Honda Conversion
Bars: Pro Taper Cr-Hi
Throttle/Clutch Lever: SX Conversion / ASV Inventions C5
Grips: Pro Taper Waffle
Nerfs: Pro Armor ProPeg w/ Heelguard
Bumper: Factory 43 w/ FourWerx 100% Carbon Fiber # Plate
Grab Bar: Pro Armor Fat Series
Front Shocks: PEP PB-1 LT ARC ZPS
Rear Shock: PEP Big Bottle ARC ZPS
Brake Lines: KTM Stainless Steel +2
Rotors F|R: KTM Fr. Floating / KTM Rear
Rims F|R: Hiper 4:1 Beadlocks/ Hiper 3:5 Dual Beadlocks
Tires F|R: ITP Quadcross MX/ ITP Quadcross MX
Body:
Plastic: KTM Hard Parts White
Graphics|Seat Cover: FourWerx Graphix
Number Backgrounds: GoForIt Graphics
Fuel Tank: Stock KTM
Hood: FourWerx Carbon
Rear # Plate: FourWerx Carbon
Others:
FourWerx Carbon Fiber Keyplate
Engine|Drive System:
Cylinder|Head: DRG Full National Stock Bore
Bore & Stroke: Stock
Valves: KibbleWhite +1mm Exhaust & +1mm Intake
Piston: CP Pistons Full Race 13.5:1
Displacement: 450
Cam: KTM Hardparts 806
Carburetor: DRG Taper Bore 43.5
Air Filter|Box: Twin Air Pro Flow
Pipe|Silencer: HMF Engineering Full System
Other:
FourWerx Carbon Fiber Rear Heatshield
KTM Hourmeter
