Somewhat off topic - once you relocate the key and lights, will any molded bar pad fit over the stem clamp?
I solved it like this. It didnt cost me anything and it works great![attachment=1119:liten.jpg]
Just two aluminum pieces with 4 holes. And one hole in the plastic for the ignition. The only thing you have to take notice is that the you dont drill the ignition hole to close to the tank, then it wount be enough space behind it.now THAT is slick! how did you do that with the lights down there?
Where did you get key cover can't find one. Thanksi bought one! and a bar pad, heres how mine looks now
i used my nuetral light cuz my on light broke when i wrecked awhile back, works just fine!
went on real easy too
It is a original part.Where did you get key cover can't find one. Thanks
