Got the following build coming but will be several weeks before I can report as I am 4 weeks away from being back in the US and having the kit:
Thumper Racing 570 Kit w/ Wiseco 12.5:1 Piston w/ Total Seal Rings (Piston 7 grams heavier than stock)
807 Cam with CrowerPower grind
Will port w/ + 1mm valves
Ceramic Coated Head & Piston
Taper Bore Carb FCR 43mm from Sredrum (Chris)
HMF Full System
K&N w/ Outerwear
Will Open Air Box
Pump Gas
Hope this all works out - should be able to stay up with the Raptors
HMF Full System
K&N w/ Outerwear
Will Open Air Box
Pump Gas
