Hi all - i hadnt ridden my 09 525xc for a while and when i went to take it for a spin the other day i found that the clutch was completely free ie it had no resistance whatsoever - i thought the discs n plates in the clutch basket might be sticky after sitting for a while - so i tried starting it in gear to see if that would free them up - but that didnt work - so i opened the clutch oil reservoir and found that it was completely dry - i remember that the last time i rode the bike (about 2 months ago) the clutch wasnt engaging well ie the bike would still move a bit when it was in gear even when the clutch was fully pulled in - im guessing that the oil was probably low from that time
so what do you suggest i do now? - a friend of mine suggested that I replace the seals as he reckons theyre probably worn out - but im not sure which seals exactly i should replace - i have checked online and found a 'REP. KIT PISTON 9.5MM 09' with part no 50302032100 which is for the clutch cylinder (on the handlebar) - see the attached parts diagram - its item no 32
but im really not sure if these are the correct seals or not - could someone please confirm which are the correct parts and if theres anything else i need to do to get this sorted properly
thanks guys
thanks guys
