Well got a helpful tip from someone on a good replacement bearing. So I went and picked them up. Much beefier than stock and slid right in. Best part about them is they can be picked up at your local napa. Bearings are about $30 a piece and seals were like $35 for both. I got mine back together tonight and it was pretty straight forward. Took about 45min total to tear down and put back together. Here is the brand and part number.
Bearings
Brand SKF
part # 32008-x You will need two.
Seals
Brand SKF
part number 19832 and 20430
Im pretty sure the first number is for the drive side. Might wanna double check when you buy. I think this will be a perminant fix. Mods might wanna sticky this if everyone agrees.
Bearings
Brand SKF
Seals
Brand SKF
