1 - 6 of 6 Posts
what jetting spec should i use on a 09 450 xc with the slip on fmf pipe , snorkel remove. i plan on using jd jetting. i'm at sea level , max altitude i'm going to be riding is under 1000fts
Id probably start by going down one notch on the needle and start with a 180mj. Thats where id start. Good luck
JD jetting comes with a very good set of directions. Only thing you need to do different is go one size smaller on the main jet than he recommends.
thanks for the info . Is there a jd jetting dealer in canada?
Discussion Starter · #6 ·
i did order directly from him , this way im sure to have the right kit hehe
1 - 6 of 6 Posts
