Hi all,
I've done a quick search and couldn't find this one so hoping it's ok to post?
I need to remove the engine from my 450 XC rocket ship as it's let go again (only 50 hours :( ) and I've got no dealer nearby where I can take it easily so need to send the engine off for rebuild. Needless to say I do not have the skill to do it myself.
Are there any key steps to taking the engine out without breaking/damaging/beating it up and leaving me a mess when I come to put it back in?
Also, are there any pistons to avoid (thinking of just replacing with a genuine KTM piston kit and valves as the price difference wasn't massive)?
Thank you in advance for any advice.
Widdi :huh:
it is lighter if you drain the oil first but is also slipperier. take your pick ha. comes out pretty easy. tip it forward a bit and pull the bottom out first then the top. or maybe its the other way around, either way it has to be tipped forward and to the side.
