1 - 5 of 5 Posts
I'm thinking of ordering a set of mud plugs for my rear Hipers because I'm tired of dirt and mud collecting in the wheels and staying there even after I pressure wash them. I'm undecided on the cheaper black plastic wheel caps or the Hiper mud plugs. I'm definitely going with the foam type inner plugs if anyone's familiar with them. Thanks in advance!
I use the hiper clear mud plugs which are not cheap. My buddy found a place that will make the lexan plugs for around $4.00 You just have to make the brackets to install them.
i know there is a pic of my quad around here some where with hiper mud plugs installed. let me look around and see if i can find it.
How did they holdup for you? The only negative I've heard was having to take them off to check the tire psi.
1 - 5 of 5 Posts
