I started this thread a few weeks ago. Since then I got an Akrapovic slip-on, so I thought I provide a review for those thinking about buying one. I'll probably get the header eventually. The header has a larger diameter than stock, as the slip-on requires a reducer that is not needed with the full system.
First the basics. The Akrapovic is titanium and extremely light. I'd guess it weights about half as much as the OEM exhaust. The box it came in weighted 6.5 lbs., so I'm thinking the exhaust weights around 5 lbs. With it you get a spark arrested quite core (94 db) and a standard spark arrestor (96 db). The fabrication is top-notch. The welds are immaculate. The carbon fiber hangers are trick. In terms of looks--WOW! I can't imagine a better looking exhaust on the KTM. It just goes with the machine. It has a nice bark too.
Now for the performance gains, I'm very impressed--especially for just a slip-on. I wish I had the actual dyno numbers, but the only thing I can rely on is the good-ol butt dyno. The most noticable difference is on the bottom end to midrange, although it also improves the topend. With the stock pipe I thought the bottom and midrange were a little tame, while the topend was impressive. Now the bottom and midrange stretch the arms and it actually needs the gripper seat. The power is more violent and the front end is much easier to loft. Most importantly, it raises the machine's fun factor by quite a few points. You'll be grinning a lot more.
Now for the downside, and I'm not talking about the price which is too high (probably because of the weak dollar). They ship it with the quiet core installed. This wouldn't be a problem if the damn thing wasn't (apparently) press fit into the exhaust with no way extracting it. Its not like there is much to grab onto, and I didn't want to crush it with a vice grip. After a great deal of frustration I finally drilled out the pop rivits, pulled off the end cap, and tried to push it out. That didn't work either, even with penetrating fluid and a mallet. Then I tried the hot/cold technique for installing crank bearings. I put the end cap in the freezer, heated the outside with a torch, and it finally came out. I wont be using the quite core anytime soon, but I can't imagine being able to switch back and forth without it being a real hassle. Learn from my experience. If you get this exhaust, expect to have "fun" getting the quiet core out.
With that frustration over, I'm very happy with the exhaust. I'm anxious to see what the header does.
