1 - 20 of 35 Posts
Can you post some more info on this & maybe a pic?
What are the 2 settings used for?
the dealer told me that the "detunned" map is so that the quad meets the strict california emissions regulations...
unfortunately i havent got to ride mine enough to figure out if that is true or not...
I pick mine up this afternoon. Still to break it in before playing anyway.
I am just trying to find out as much as possible so I can put a plan in place.
the hot mode is for holeshots and long straight aways and the soft mode is for in tight stuff so you can controll power easier, It does work and for sure you need switch to change on the fly.
Thanks mcracer. Starting to understand it now.
Are switches readilly available?
It's very hard to find anything here in Australia.
should be able to get at your dealer. its the same one they use on their bikes there is also an aftermarket called vortex
Discussion Starter · #13 ·
that is correct just unplug the brown wire and plug the switch in easy.
thanks for the confirmation.
maybe if you had the time, you could write up a quick how-to that can be pinned for future reference. pics would be sweet as well...
i ordered it but they were out of stock, so it will be a week or so before i receive it, otherwise i would do it.
thanks again for your contribution!
· Administrator
Underneath the front cover is a small white connector. Unplugged is for the performance map and plugged in is for the de-tuned map. I will get some detailed pictures up ASAP.
does this apply on the 450, lots of plugs and wires under tehe, a picture would be greatly appreciated
just when you get the map selector switch just dont pay attention to the directions the info and the pics are for the bike no the quad just unplup brown white wire and plug in switch it its done its so easy a caveman could do it lol
· Administrator
have a look under the dood, there are at least four plugs with a brown wire as part of the plug, which one do you unplug........ not to mention there are two pairs of bare plugs, each with a brown wire, not connected to anything...........
clearly the 525 is different than the 450 ????
if you've done it ??, how about a picture to help the rest of damn arses....
sure i can do that. but the prob i run into i dont have a my quad stored where there is light and i get home after dark but if no one gets a pic up on here before sat i can post it then
the is a black box on the right side of the front of the frame there its the brown and white wire thats connected with a male female conector (its clear and round like a lil tube about 1 inch in length and plugs into each other) just pull it apart and you have race mode plug in the switch then you can toggle between race mode and soft mode and i have no clue what those other plugs are
· Administrator
is this the plug, brown wite wire one end, black the other, below the CDI comes out of the main loom ???
is this the plug ?
brown and white wire is below my finger..... right behined the head light
spare wiring plugs on 450
on the 450 there are 4 plugs, 2 pairs, located on the lhs ????? any ideas.....
1 - 20 of 35 Posts
