I was having a problem with the HID (Eagle eye HID Kit) head light flickering when I was ridding. This was not good while traveling through the dunes at speeds.
The issue with the HID light flickering is that the power wire providing power to the ballast is too small and not giving the ballast sufficient power to light the HID bulb causing it to turn off and on.
The solution to this problem was to add a relay. Now the bulb has sufficient power to light up and stay on. I also noticed that the light is brighter than before.
The relay works with the light switch on the handle bars.
I did this to all three quads.
Here are some pics.
Here are some pics.
