1 - 13 of 13 Posts
id like to know how much does it go for in the states,does anyone know who is the cheapest....im asking this because up here in canada it goes for 1200 bucks.......whitout tax......and up here the tax is 15%..........help
Works fine, the kit is called a 570 but really is 554 cc, while the motor is apart have someone unshroud the valves,
Im a big fan of the 570 big bore kit. It works very nice!
We sell them as well.
It is actually a 556 (99mm) they run hard.
Thanks
Kam Gray
KBR
Will do, thanks.
12:1 is it, but Im really considering making a piston in a higher comp for that kit.
Ill pm you in the am
Thanks
Kam Gray
Discussion Starter #9
so i can just slap that on and not change anything else......ANYTHING
Discussion Starter #11
Thanks
Kam Gray
KBR
u sell them......how much does the kit go for and what do u get when u buy the kit..........
Unshroud the valves=
the head used on the 525 95mmbore, is the same head used on the 450 89MM bore, HP can be gained by removing material from around the outter edge of the combustion chamber, talk to Kam or who ever does your big bore kit, you don't have to have a full blown port job, minor clean up helps hp, not as much as a good port job, but way cheaper if you on a budget
Discussion Starter #13
thanks thats helps alot
1 - 13 of 13 Posts
