1 - 1 of 1 Posts
My 07 IRS broke a rod a couple years ago and busted the case by throwing the counter shaft through the front. So I pulled the cylinder to find the problem and there it was. My question is since I’m going to be in the bottom end I want to completely rebuild it. Replace all bearings and common wear items. Does anybody offer a complete bearing and seal kit for these? All I can find is individual bearings and I’m not familiar with everything that’s in there. It all ready had a 806 cam and 12:1 piston but the plan is weld my cylinder install a sleeve and go 540. I all ready have new cases. Just need to find where to get everything and a little info on what usually needs replaced other than bearings while it’s apart. I want this to be bullet proof when it goes back together. It survived 13 years of abuse on pavement the first time. I want 13 more the next round. Thanks
1 - 1 of 1 Posts
