So went to the dyno with my new 42mm taperbore compliments of Walt, and some u4.2 to test out. Anyways I forgot to print both graphs but the bored carb lost power all the way up to about 6500 then started to take over up top. Taking the peak to about 55.2 and then leveled off to stock area. Im guessing once cams and piston come into play it will be better. Then drained the pump and added u4.2. Power across the board. Peak went to over 56whp and torque is huge now. 39ftlbs. Im super stoked with this machine. Pulls like crazy!!!!!!!! Here is the graph. Once I have 14.1 piston and cams this thing will do around 60whp easy and torque should be insane. I cant wait. Enjoy and more to come dont you worry.
