Sredrum (Chris) over on YFZtech has the FCR carb boring wired. General concenses over at KTM Talk is that the FIRST mod on a 525 should be a 41mm carb
this is the link to Sredrums section on YFZtech.
FCR carb boring
The stock 39mm can be taken out to 41mm easy enough, to go larger you will need a new central section insert, Sredrum has these for 43mm and 44mm. Apparently DASA also makes a 43mm central insert
43 and 44mm central sections
FCR carb boring
